Multi Channel Speech Dialler
esp-protocol
The texecom unit does 4 inputs (you could fit 2 to the same phone line???)
Anyone ever heard of or can anyone recommend a Multi channel (preferably 8 way) speech dialler, along the lines of an SD2??
Thanks
I am fairly sure the SD3 has 8 inputs A,B,C,D,E,F,G & H. Pricy though but it will take a sim card as well as the landline.
Trade Member
I thought the SD3 was the same as the SD2 (4 channel) but had GSM facility or something similar...??
Phone call to Gardiners tomorrow.....
Thanks....
Just had a look in the Gardiner Catalogue....
SD2- 8 inputs, 4 outputs, and a funky blue backlight.
SD3- Same as the above, but with the addition of the GSM module.
Hope that helps you.
Oh, anyone tell me why you would want an ambient temperature sensor in a speech dialer?
Comms room monitoring?
hot air detector?
:lol:
regs
alan
what would be the ideal temp for a comms room, can the SD3 it be adjusted?
out of interest can the SD3 be used GSM only? i'm seriously curious as my current job won't have lines till post new year
regs
alan
regs
alan
have a look at riscos offer sheet arf
