ianamac Posted December 13, 2007 Posted December 13, 2007 Hello, Recently moved into a property with a Veritas R8 system. I was left instructions on how to change the pin number which I`ve done but what I need to know is how to turn the mains power off. As soon as i flick the switch it goes into tamper. How do I silence the alarm to do any diy in the house. Any help much appreciated.
amateurandy Posted December 13, 2007 Posted December 13, 2007 Hello, Recently moved into a property with a Veritas R8 system. I was left instructions on how to change the pin number which I`ve done but what I need to know is how to turn the mains power off. As soon as i flick the switch it goes into tamper. How do I silence the alarm to do any diy in the house. Any help much appreciated. It should have an internal battery to keep it working properly through several hours of power cuts....... But they don't last forever - maybe 4 or 5 years? Has it been serviced recently?
satsuma01 Posted December 13, 2007 Posted December 13, 2007 Hello, Recently moved into a property with a Veritas R8 system. I was left instructions on how to change the pin number which I`ve done but what I need to know is how to turn the mains power off. As soon as i flick the switch it goes into tamper. How do I silence the alarm to do any diy in the house. Any help much appreciated. sounds like the internal battery is dead so it would need replacing. either go down the local wholesalers and ask them for a new one or if you dont feel confident about touching things in the panel then call in an alarm engineer. "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
ianamac Posted December 14, 2007 Author Posted December 14, 2007 Hello, Recently moved into a property with a Veritas R8 system. I was left instructions on how to change the pin number which I`ve done but what I need to know is how to turn the mains power off. As soon as i flick the switch it goes into tamper. How do I silence the alarm to do any diy in the house. Any help much appreciated.
ianamac Posted December 14, 2007 Author Posted December 14, 2007 It should have an internal battery to keep it working properly through several hours of power cuts.......But they don't last forever - maybe 4 or 5 years? Has it been serviced recently? Thanks for that, not sure when last serviced but will now get someone in to sort it out
