Texecom Excel
GrahamUK33
I bought a 2 bed semi a while ago and would like to have an alarm fitted. I dont have loads of money to install something expensive, but I have found a Texecom Excel Kit.
How would you rate the Texecom Exel kit for a cheap alarm system?
Does anyone have one of these installed and if so what do you think of it?
Would a novice be able to install this kit?
Would you stretch your budget to go for the Texecom Premier Fully Featured Burglar Alarm System / Kit? if so what would the benefits be.
Thanks, Graham.
Graham
twitter: ithorizon1
http://www.ithorizon.co.uk
Thanks, Graham.
Texecom Excel is an ok system for DIY can't say its bad. Premier is what our company uses and can be complex if you don't know what your doing. I would normally say get a couple of quotes and get a decent system. But It's your money to budget. We use texecom for premier only
Yes the veritas excel will be fine for this purpose. in this sort of install I would only think about the premier if you need more than 8 zones.
Good Luck
texecom 'good kit', to date never had any problems using their kit.......imo.
  • 3 weeks later...
I used to use excel all the time but found on a few jobs i was having to install a mainspike filter, so ive lost interest a little bit, but other than that its a cracking panel/keypad.
I use premiers but might be a headache for you to programme.
  • 8 months later...
How many zones would I need in a 2 bed house? does every room need a zone or would the whole house come under a zone?
Hi, it depends on the house layout, a zone is just one device-whether it be door contact,PIR or panic button for example, an 8 zone panel should be more than enough for your requirements though IMHO.
Richard.
