jogillies Posted December 18, 2007 Posted December 18, 2007 Hiya i have a compact alarm system which was installed when i moved into our house 4 years ago without a manual. It is used everyday with no problems until last night the alarm went off for no reason and now i cant cancel the flashing blue light outside like i normally do with the reset button. Anyone got any ideas as to whats gone wrong thanks !!!!!
alterEGO Posted December 18, 2007 Posted December 18, 2007 Hiya i have a compact alarm system which was installed when i moved into our house 4 years ago without a manual. It is used everyday with no problems until last night the alarm went off for no reason and now i cant cancel the flashing blue light outside like i normally do with the reset button. Anyone got any ideas as to whats gone wrong thanks !!!!! Your system requires a service, i'm guessing you have not had it serviced since the install. Here are the checks that are carried out on a annual service [*]Check history of alarm system since last maintenance service [*]Visual inspection of all major alarm components including cabling & connections where accessible for signs of deterioration or damage [*]Check mains power supply including charging rates [*]Check battery power supply including charging rates [*]Check and Walk Test all detectors [*]Check satisfactory operation of manually operated devices e.g. panic buttons [*]Check and test all audible warning devices
jogillies Posted December 18, 2007 Author Posted December 18, 2007 Hiya i have a compact alarm system which was installed when i moved into our house 4 years ago without a manual. It is used everyday with no problems until last night the alarm went off for no reason and now i cant cancel the flashing blue light outside like i normally do with the reset button. Anyone got any ideas as to whats gone wrong thanks !!!!! for that your right its not been serviced will sort that asap thanks again.
alanrh Posted December 29, 2007 Posted December 29, 2007 Hiya i have a compact alarm system which was installed when i moved into our house 4 years ago without a manual. It is used everyday with no problems until last night the alarm went off for no reason and now i cant cancel the flashing blue light outside like i normally do with the reset button. Anyone got any ideas as to whats gone wrong thanks !!!!! Did you have any luck with getting hold of a manual as im having a similar problem?
