3 Panic Buttons
sven
ENGINEERS CAN YOU HELP,i HAVE ONE CIRCUIT LEFT ON A SCAN 9651 TO PUT 3 PA BUTTONS ON USING 2K2 AND 4K7 EOL RESISTORS AND CANT SEEM TO GET IT WORKING.
I KNOW I PROBABLY GOT SOMETHING MIXED UP BUT NEED TO BE PUT IN THE RIGHT DIRECTION.
THANKS
SVEN
Guest anguscanplay
this for yourself or for gain?
are you wiring from pa to pa or do all the pa's come back to the main panel on their own wires
What has this got to do with the Question. Please stick to what the member is asking
I saw Angus had replied to this question in the correct way but it seems to have been deleted......
Better delete the question if you don't want it answered....... :P
My Amateur Radio Forum
Guest anguscanplay
okay I`ll post again
it has everything to do with answering the question -
if its for yourself just put the resistors in the panel
if its for a customer you need to use a third wire to carry the circuit round and allow the resistors to be fitted at the end of line
I`ll refrain from having a dig (that privaledge is reserved for the Mods)
:Whip:
Must admit to being curious - third wire?
if you have wired from c/u to !st PA and then to 2nd and then to 3rd you just connect up in parallel using two wires put alarm resistor in parallel to PA contact in No's 1 and two and and similarly in No. 3 you put said alarm resistor in parellel and then the EOL in series.
If any One PA is pressed the panel see EOL + alarm resistor(s).
You would do it simarly if wiring is wired in seperate wires back to c/u or you could (doing it like a cowboy) put alarm resistors etc in c/u but that is not good practice.
If the original poster wants a diagram i,m sure somebody knows how to put one here
p
THE BLACK KNIGHT
if you have wired from c/u to !st PA and then to 2nd and then to 3rd you just connect up in parallel ? using two wires put alarm resistor in parallel to PA contact in No's 1 and two and and similarly in No. 3 you put said alarm resistor in parellel and then the EOL in series.
p
