Selsport69 Posted December 20, 2007 Posted December 20, 2007 Is it possible to view all your call records on Nokia PC Suite. I can view messages etc but i cant find anywhere where I can view calls received missed etc. I connect via blue tooth to my pc. If Nokia PC Suite dosent do that is there a programme that is available so that I can view call records on the PC. Thanks Kev
jptaylor Posted December 21, 2007 Posted December 21, 2007 Is it possible to view all your call records on Nokia PC Suite. I can view messages etc but i cant find anywhere where I can view calls received missed etc. I connect via blue tooth to my pc.If Nokia PC Suite dosent do that is there a programme that is available so that I can view call records on the PC. Thanks They are series 60 handsets so yes Nokia PC suite should have the call register to view for each Nokia paired with it,are you using the latest version of PC suite,also some functions are not available via certain Bluetooth adapters,have a dig around on Google as you may need WIDCOMM XP/Vista drivers for best operation of series 60 devices.
