Guest Cerberus NI
does anyone know how to put the minerva mx2 panel into one man test (if it has one that is) :cold2:
That'll be the conventional one then??It involves pressing a small button located on the pcb - are you an engineer??
MX2 is an analogue? :hmm:
My Amateur Radio Forum
Guest Cerberus NI
Sorry - slight brain melt moment!Was thinking of the MX-C (where the C refers to conventional!)
I too have these moments!
To much canned smoke in my yoof! :rolleyes:
The fast access code for walk test is 71
Pete
Peter Robinson
Freelance
M:07889038650
sorry sparky999 your thinking of the minerva 80 the mx2 doesnt use fast access codes if memory serves, should be under user 02 code 2222 if not then would need to be programmed from engineer level
All comments in this post are my own views and do not necessarily reflect the views of my employer
i humbly stand corrected
  • 1 year later...
use o1 code 1234 then menu number 7. this is service menu, then follow the on screen menu ,enter the option for one man test all zones. this will only allow you to end when clear of fire signals. this menu is ended by pressing f5.
hope this helps :beer:
eddy:beer:
