Tamper Fault - Modern Alarm 3200
Discokid
Hi all,
I'm having problems with a "tamper fault" on a Modern Alarm 3200. The alarm intermittently goes off every 30-90 minutes with no sign of tampering. The reset code has no long lasting effect on the system.
All suggestions and help welcome.
probably the battery.
Scannies (which that is) have a battery fault circuit built in which is part of the 'tamper' circuit
paul
THE BLACK KNIGHT
Hi all,
Hi there,
here we go, what is the display showing when this occurs?
There are a number of Event Log Displays that show on the Keypad, different ones mean different things, get back to us with the exact display, along with any lights that are also showing and we'll see what we can ho for you.
By the way the Modern Alarms 3200 is a re-badged Scantronic 9800
magpye
so if it is battery fault you will set 'bf' ,if it is a problem with your external bell/sounder you will get 'tr' or if it a problem with a detecteor it will say 't1' to t8'. There is a load more so as magpye says you need to get back to us with the exact readout.
paul
THE BLACK KNIGHT
