Scantronic 9800 - Error 6f
needhelp
Recently my alarm has been sounding in the middle of the night with the Error 6F. I clear this but it continues to go off every 30 mins for about 4 hours which is becoming very frustrating. Can anybody give me advice on how to stop this?
Is the code 6F or is it really BF for the Battery?
Any help would be much appreciated asap!
could well be the battery, better be quick 'if' you need an engineer, it will be at it all over the holiday
Guest anguscanplay
Battery fault - the system is detecting the back up battery has had it`s day ( you should be able to work out what you need to do to stop the system detecting the battery)
Battery f[/b]ault - the system is detecting the back up battery has had it`s day ( you should be able to work out what you need to do to stop the system detecting the battery)
the battery needs replacing by the sounds of it, if you feel confident to do it yourself then please proceed with caution as mains voltage which is lethal and can kill is present in the panel.
if you dont feel confident about replacing the back up battery in panel then ask a local company who sahould charge between
07475071344
Many thanks for your help. If we set the alarm overnight will that prevent it from going off due to not using the back up battery? Also, we have a spare battery but just wondered if you could advise whether the settings are lost when you change a battery over?
Thanks
Change the battery ASAP, or you'll regret it when it starts going off at 3am and repeats it every 5 minutes.
