Power Delay Option & Other Options - Galaxy Panel
cjd
hi guys, been on here loads today about a backup battery prob (which i may is is now sorted!!) thanks to all who posted and gave ideas. i was altering some of the settings and have come across on that is called "Power Delay" what exactly is it for?
another menu brings up option to input the battery capacity eg 7Ah and how long it will last e.g. 1hour etc. is there a point to this menu option or not?
thanks in advance
craig
thanks in advance
craig
If you don't have the manual how on earth are you managing to program this panel?
This parameter determines the delay between the activation of AC Fail outputs following a mains failure to allow the power to return before signaling the fault. The Power Delay is programmable within the range 0-50 mins
Battery stand by for the system should be 8hrs, you'll have to work it out and add PSUs if necessary.
have got the "baiscs" such as what extras the * and # keys provide and a very brief description of what some menu do. other than I have just had a go and worked it out.
as i don't have an outpur configured for AC fail then thats an option that doesn't worry me. thanks for the info. :-)
Just a quick question on a complety different tangent are you installing the alarm for your piece of mind or are you telling your insurance company so you get some sort of discount?
regs
FCE
All comments in this post are my own views and do not necessarily reflect the views of my employer
No it's not for insurance discount. I realise that for that it would have to be maintained by a company and installed by one!! the system is more for piece of mind and to ensure that emergency doors are kept soley for emergencies. it a campsite so large numbers of people use it, the system also allows us to restrict access to different part of the buildings which helps us to keep visitors only int he bits they have hired.its a DIY job and is by no means professional, but i must say i am pleased with what i've been able to do re:-programming etc. (with help from postings on here!!)
You're scaring me to death on your liability and the risk to your customers!
Public, restricted access etc. downright dangerous if not done right. Your insurers would have kittens.
GET IT DONE PROFESSIONALLY.
when i say restrict access, i don't mean an electric fence!! i simply mean that different parts of the building remain alarmed if they're not being used. the fire exit doors are on a security loop which activitates a sounder to indicate that's it been opened. the system has 3 pir's inside and obviously the main extry/exit on a door contact. i can't see any problem with that. The system ISN't used to reduce insurance (i am fully aware that the system would need to be installed and maintained by a registered company) hence the fact it's just for peace of mind so that myself and other staff can leave the site knowing that it has some security.
have you thought of installing cctv?
07475071344
have a very basic PC based system which i've put together. its' not the best, but does the job of deterring dog walkers and the like who shouldn't be on site - and before anyone one here says anything - YES we do have signs up!!alarm system for peace of mind, cctv for same and also for deterrent.
Please dont take it as were flaming you or anything just making sure you have covered all the bases, dont want anything untoward to happen if you were to miss something
So are your Fire Doors programmed as 24 hour zones so that even with system unset they will still set alarm off should they be opened??
