DES Posted December 28, 2007 Share Posted December 28, 2007 need to reprog gardtec speech dialler can anybody explain how to crash. fitted for a friend foc . i cannot, for the life of me remember if the nvm can be reset to factory setting. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/ Share on other sites More sharing options...
alterEGO Posted December 28, 2007 Share Posted December 28, 2007 need to reprog gardtec speech dialler can anybody explain how to crash. fitted for a friend foc .i cannot, for the life of me remember if the nvm can be reset to factory setting. Due to site rules and common sense we cannot inform you of the methods used to crash security equipment. Although it can be reset. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-187152 Share on other sites More sharing options...
DES Posted December 28, 2007 Author Share Posted December 28, 2007 Due to site rules and common sense we cannot inform you of the methods used to crash security equipment. Although it can be reset. i understand thanks that does help. i have a user manual. is there a installation manual ? if so im sure i can get hold of one. or i will call manufacturer when back at office. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-187156 Share on other sites More sharing options...
alterEGO Posted December 28, 2007 Share Posted December 28, 2007 is there a installation manual ? if so im sure i can get hold of one. or i will call manufacturer when back at office. one in the same if i remember right. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-187157 Share on other sites More sharing options...
DES Posted December 28, 2007 Author Share Posted December 28, 2007 one in the same if i remember right. do you mean ? one and the same if so i v read it back to front took 2 mins. thanks anyway Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-187158 Share on other sites More sharing options...
Guest anguscanplay Posted December 29, 2007 Share Posted December 29, 2007 Due to site rules and common sense we cannot inform you of the methods used to crash security equipment. Although it can be reset. i understand thanks that does help. i have a user manual. is there a installation manual ? if so im sure i can get hold of one. or i will call manufacturer when back at office. have to ring tech support I`m afraid - there shut till the new year now Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-187166 Share on other sites More sharing options...
inglishg Posted March 22, 2008 Share Posted March 22, 2008 Had some fun with one of these diallers today (yeah, I have been working on Good Friday ) The customer announced that they could not get it to phone them. Checking the circuits and programming revealed nowt. The phoneline is not broadband, and everything checks out good. Unplugging the bt cable gives a LF message, but I just cannot get it to call when its all connected back up. So, I replaced the whole dialler unit. Nowt better - exactly the same fault. Has anyone any thoughts please? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-193530 Share on other sites More sharing options...
antinode Posted March 22, 2008 Share Posted March 22, 2008 Had some fun with one of these diallers today (yeah, I have been working on Good Friday ) The customer announced that they could not get it to phone them. Checking the circuits and programming revealed nowt. The phoneline is not broadband, and everything checks out good. Unplugging the bt cable gives a LF message, but I just cannot get it to call when its all connected back up. So, I replaced the whole dialler unit. Nowt better - exactly the same fault. Has anyone any thoughts please? Can you not get the unit to trigger at all? If not, try triggering the dialer through a transistorised relay instead of off the bell trigger (I'm making an asumption here You could also try fitting a 1k resistor between the trigger input and a neg to pull the input all the way down to 0v when triggered. Have you tried putting your test phone on the line and listening in to what's happening when it's trying to dial out? Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-193531 Share on other sites More sharing options...
arfur mo Posted March 22, 2008 Share Posted March 22, 2008 Can you not get the unit to trigger at all? If not, try triggering the dialer through a transistorised relay instead of off the bell trigger (I'm making an asumption here You could also try fitting a 1k resistor between the trigger input and a neg to pull the input all the way down to 0v when triggered.Have you tried putting your test phone on the line and listening in to what's happening when it's trying to dial out? nearly the right info - but wrong resistor value suggested and fit it between 12v + AUX and trigger, use 2.2k minimum just to pull the input more positive when not active, as the unit needs a decently defined voltage swing to negative to operate it (as do most dialers because iof the action of shokty input gates). regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-193550 Share on other sites More sharing options...
Guest anguscanplay Posted March 22, 2008 Share Posted March 22, 2008 check they`ve paid their phone bill? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21755-gardtec-speech-dialler/#findComment-193553 Share on other sites More sharing options...
