Tel Posted January 2, 2008 Posted January 2, 2008 Below is his final reply on another Forum where the exact same question was asked, I like the last bit expect any better?
Guest anguscanplay Posted January 2, 2008 Posted January 2, 2008 but I did "fleece " someone this very afternoon - it`s called supply and demand but I dont expect general members of the public will understand
arfur mo Posted January 2, 2008 Posted January 2, 2008 Hi All,First time poster here so happy new year to all. Foolishly I decided today of all days to change a PIR that's been playing up for a while. I took the cover off the PIR and the control panel alerted me of a Tamper to which I reacted and entered the code to silence the internal siren. I continued to disconnect the wiring (which is where my problem started to kick in i think) and the external alarm started blaring! Although the internal siren was not blaring it was possible to quietly hear it. In an attempt and panic to turn it off i entered the master user code but that didn't work after which i pressed anything that might. Nothing worked and after about 30 mins the external siren ceased thankfully. Unfortunatley I'm unable to get anything working. The Tamper light stays on and I think by disconnecting the wiring caused the system to 'alert' of a bigger problem than just removing the PIR cover which alerts of a Tamper. I'm sure I need to do some sort of master reset because I can't get anything to work even though I have the engineer\master code. Any suggestions would be appreciated. Thanks - kkp best bit of advice on this site is to just ignore that young upstart (alterEGo) as he just so jealous, i am liberated by my ability and expertise while he is confined by his . good natured banter aside, you have most likely blown a fuse, so if you have connected your new detector following the colour code from the old one, replacing the fuse should hopefully redeem your system. i have to advise you to have the remedial works done by a competant engineer as opening the alarm panel can present a risk of a fatal electric shock or injury from a falling battery to you. i am in Wickford, so please PM me for phone numbers etc if required. regs alan PS alterEgo If you think education is difficult, try being stupid!!!!
barooga Posted January 2, 2008 Posted January 2, 2008 Time warp in Essex Arfur?? Growing old is mandatory, growing up is optional
alterEGO Posted January 2, 2008 Posted January 2, 2008 best bit of advice on this site is to just ignore that young upstart (alterEGo) as he just so jealous, i am liberated by my ability and expertise while he is confined by his .regs alan PS alterEgo
Guest anguscanplay Posted January 2, 2008 Posted January 2, 2008 Arf still having a very MERRY Christmas ?
arfur mo Posted January 2, 2008 Posted January 2, 2008 Time warp in Essex Arfur?? i never miss a chance to fleece someone regs alan If you think education is difficult, try being stupid!!!!
