boywillys Posted January 1, 2008 Posted January 1, 2008 Hi Looking for some help, I have a veritas R8+ with RKP, well my sister does lives 120 miles away. The main control box and RKP started buzzing I presume these are internal alarms. When the code is put in the the alarms stop but start up again after approx 10 mins. I was visiting over Xmas and had a look there are no zone lights on and no tamper lights on. I did disconect the alarm sounder/speaker in the main control box to reduce the noise while trying to solve the problem but the alarm in thr RKP is still sounding the only way to stop it is by dissconecting the mains and battery. This alarm system is at least 10 years old and this is the first time she as had a problem, which I think is good going. If the system is on the mains does it need to have a battery for the alarm system to work I dont think she as ever replaced the battery. But surly this would this only cause a problem during a power cut, ie no battery back up. As long as the mains is on the system should function OK yer? thankyou very much in advance for any help or advice any one on the forum can give me. manythanks.
Guest anguscanplay Posted January 1, 2008 Posted January 1, 2008 I would start with a new battery and take it from there
alterEGO Posted January 1, 2008 Posted January 1, 2008 stupid computer Good work man and tools springs to mind As angus says battery would be my best guess.
satsuma01 Posted January 2, 2008 Posted January 2, 2008 Good work man and tools springs to mind a bad workman always blames his tools "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Adi Posted January 2, 2008 Posted January 2, 2008 Depends how kinky she is. I really can't be ar**** with it anymore.
satsuma01 Posted January 2, 2008 Posted January 2, 2008 can I drill a hole with the PC ? angus course you cant jeez what ever next hanging the washing on the sky cable "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
boywillys Posted January 6, 2008 Author Posted January 6, 2008 Hi all tried a new battery in the alarm but as not solved the problem, any more ideas would be much apreciated. mant thanks
alterEGO Posted January 6, 2008 Posted January 6, 2008 Hi alltried a new battery in the alarm but as not solved the problem, any more ideas would be much apreciated. mant thanks did they totally power down the system? tbh with you, the more messing about, the more time she is left un protected from intruders. it would be quicker an more cost effective for her to get a local engineer round. where abouts is she?
