Gardtec 300
DaveUK
Happy new year folks
I have a gardtec 300 series alarm that was making a continous beeping sound so i put in the code and now all it does is flash the red power light with the day light on green. All the sensors red light on the walls are out now as well.
Does anybody know what this means?
cheers for any help guys.
Guest anguscanplay
you been doing any DIY around the house ?
Guest anguscanplay
Putting carpet down but thats about it.
cheers for the quick reply
thought so - you`ve probably cut through a cable and blown a fuse, at the least it sounds like you`ve got a tamper fault
Yeah found the wire with the offending hole in it. Just need to get somebody to splice it together again and back in business.
Once again thanks for your help.
Guest anguscanplay
where abouts are you Dave ?
