Gardtec Speech Dialler
Ding Ding, too your corners please! and stay there!!!!!!
:lol:
arr angus tut tut
arr arfur tut tut
:lol:
07475071344
Guest anguscanplay
wrong again,
the words in mypost 2 were you might need (not you will need) to fit resistors, as in if the panel needs them. you might also note the o/p said a little later he had fitted resistors to the dialer and asked if they were also needed in the panel.
and cause your ignoring my question - what has adding resitors got to do with a line fault ? you might as well have asked him if the tyres on his car were blown up correctly (well he would need to do them at some point in the future, so why not ask that instead of not answering his question, instead)
Guest anguscanplay
your advice was aimed at the socket connections when he had used a line cord.
regs
alan
that goes someway to explaining your confusion (gets more regular at your age) so YOU misunderstood " check your connection ON THE DIALLER" as a repeat of earlier advise to "check your connection AT THE SOCKET" :no:
shame, we could have kept from adding to your post count if you had read it properly first time
Right This has run its course :closed: before it gets nasty
All comments in this post are my own views and do not necessarily reflect the views of my employer
