Guest anguscanplay Posted January 16, 2008 Posted January 16, 2008 the profile one you goon. yep thats the one LOL - I was just assuming the system was years old, woops
tommi Posted January 16, 2008 Author Posted January 16, 2008 Have you checked the tamper in the control box??If not and it sounds silly it could be a faulty bell and i know it should come up BB but it has happened!I have briefly checked the tamper in the control box and it seems fine. I will check it again (at a more suitable hour !)You're not the 1st to suggest the bell... looks like i need to get the ladder out at the weekendThanksnah its none of the above - simply " stretch " the spring in the keypad they get over compressed and dont quite work in line with the lidI'll gve that a try, thanks
Guest anguscanplay Posted January 16, 2008 Posted January 16, 2008 ThanksI'll gve that a try, thanks mine first - save yourself a wild goose chase
tommi Posted January 17, 2008 Author Posted January 17, 2008 mine first - save yourself a wild goose chase Tried it..... no luck! Is here anything I need to do to the RKP after trying it though? Should I reset it? or should I expect the fault to instantly go away?? Thanks in anticipation
Guest anguscanplay Posted January 17, 2008 Posted January 17, 2008 Tried it..... no luck! Is here anything I need to do to the RKP after trying it though? Should I reset it? or should I expect the fault to instantly go away??Thanks in anticipation take the keypad lid off stretch the spring and make sure its centered on the little button thingy put lid back on - you should hear the spring "springing..." and feel a "bounce.." in the lid set system unset system should be back to normal
tommi Posted January 17, 2008 Author Posted January 17, 2008 take the keypad lid offstretch the spring and make sure its centered on the little button thingy put lid back on - you should hear the spring "springing..." and feel a "bounce.." in the lid set system unset system should be back to normal Thanks mate, as I assumed... I did just that but no joy, still the same tamper fault (Ct)
Guest anguscanplay Posted January 17, 2008 Posted January 17, 2008 Thanks mate, as I assumed... I did just that but no joy, still the same tamper fault (Ct) did you happen to take the lid off the keypad earlier ?
arfur mo Posted January 17, 2008 Posted January 17, 2008 take the keypad lid offstretch the spring and make sure its centered on the little button thingy put lid back on - you should hear the spring "springing..." and feel a "bounce.." in the lid set system unset system should be back to normal 'Ct' according to the manual is definitely a problem with the remote keypad, possible you have dislodged a wire in it or the lid contact has gone duff. i'd try operating the tamper contact several times with you finger to clean it up, as might have got some decorating dust in it. also the terminal cover can be a real pest to get back properly, so try holding the contact spring in with your finger then set and unset to see if it clears, if so it's the adjustment of the spring. if not, have it upgraded to a G490 panel, far better unit. regs alan If you think education is difficult, try being stupid!!!!
tommi Posted January 17, 2008 Author Posted January 17, 2008 did you happen to take the lid off the keypad earlier ? I did indeed.
tommi Posted January 17, 2008 Author Posted January 17, 2008 'Ct' according to the manual is definitely a problem with the remote keypad, possible you have dislodged a wire in it or the lid contact has gone duff.i'd try operating the tamper contact several times with you finger to clean it up, as might have got some decorating dust in it. also the terminal cover can be a real pest to get back properly, so try holding the contact spring in with your finger then set and unset to see if it clears, if so it's the adjustment of the spring. if not, have it upgraded to a G490 panel, far better unit. regs alan I have checked the wires and i'm pretty sure they are all fine... I have also 'manually' operated the tamper control and it appears fine. There is clear definition between on and off both audible and by feel. I'm very tempted to upgrade anyway as I would like to add a dialer... i'd be interested to hear what upgrade path you guys would recommend. As for the fault.. i'm determined to fix it first! thanks for all the suggestions.
