ritchie4433 Posted January 9, 2008 Posted January 9, 2008 moved to house and got Optima XM6 alarm which we cant use. I have moved in about three months ago and there is an alarm fitted to the house but I cannot use it as the previous owner has not got the alarm code number. Is there any way that I re set the system and change the code to one that I can use? The alarm is sitting there redundant and I would be very grateful if anybody could advise me. Many thanks, Doug.
topalarms Posted January 9, 2008 Posted January 9, 2008 moved to house and got Optima XM6 alarm which we cant use. I have moved in about three months ago and there is an alarm fitted to the house but I cannot use it as the previous owner has not got the alarm code number. Is there any way that I re set the system and change the code to one that I can use? The alarm is sitting there redundant and I would be very grateful if anybody could advise me. Many thanks, Doug. Local enginner could do that for you.
sjrapid Posted January 13, 2008 Posted January 13, 2008 moved to house and got Optima XM6 alarm which we cant use. Are you sure about the model? There was an XM, or and XL6, but I've not seen an XM6. Confirm which model it is, and we can give you some pointers... best regards -- Steve
FASTCAR Posted January 13, 2008 Posted January 13, 2008 XM6 is basically the same as XM ...only with 6 zones.
camerabloke Posted January 13, 2008 Posted January 13, 2008 LOL @ now you have the choice.Doorstop or bin? Sorry, just had to do it. I will see if i can find an user guide in my manuals for you Eucam Security Systems 0845 4630 746 www.eucam.co.uk
sjrapid Posted January 16, 2008 Posted January 16, 2008 XM6 is basically the same as XM ...only with 6 zones. Ah - thanks! Seen loads of 4-zone XMs but never a 6. The reset method for XMs is documented in the XM engineers manual best regards -- Steve
