james69 Posted January 9, 2008 Share Posted January 9, 2008 Hi, I have just had my hall re-plastered and the plasterer removed my sounder for my alarm system (scantronic 9651) the problem is that he has removed the wires and there are now a green and a white cable (from the wall) and I'm not sure which one is the + (suspect that it's the white one) Is this simple enough for me to re-wire or will I have to call out the engineer? Many thanks James Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21855-scantronic-9651-sounder/ Share on other sites More sharing options...
Guest anguscanplay Posted January 9, 2008 Share Posted January 9, 2008 james69 said: Hi, I have just had my hall re-plastered and the plasterer removed my sounder for my alarm system (scantronic 9651) the problem is that he has removed the wires and there are now a green and a white cable (from the wall) and I'm not sure which one is the + (suspect that it's the white one) Is this simple enough for me to re-wire or will I have to call out the engineer? Many thanks James is it a sounder or a Loudspeaker ? sounder will have a printed curcuit board in it but a speaker (shut up Arf !) will usually just have a chocblock type connector ? if its the latter then it doesnt matter but if its the sounder you will either need to check the same connections inside the panel OR test it with a test meter if your alarms on service then you HAVE to pay the firm to call and do it - sorry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21855-scantronic-9651-sounder/#findComment-187928 Share on other sites More sharing options...
james69 Posted January 9, 2008 Author Share Posted January 9, 2008 anguscanplay said: is it a sounder or a Loudspeaker ? sounder will have a printed curcuit board in it but a speaker (shut up Arf !) will usually just have a chocblock type connector ?if its the latter then it doesnt matter but if its the sounder you will either need to check the same connections inside the panel OR test it with a test meter if your alarms on service then you HAVE to pay the firm to call and do it - sorry Thanks Anguscanplay, It's the speaker with the chocblock connector. So it's best to give the installation firm a call because it's under a service contract.? James Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21855-scantronic-9651-sounder/#findComment-187937 Share on other sites More sharing options...
Alarm Protection Posted January 9, 2008 Share Posted January 9, 2008 You may get charged for this but it is better to give your service company a call to check the system. ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21855-scantronic-9651-sounder/#findComment-187949 Share on other sites More sharing options...
Guest anguscanplay Posted January 9, 2008 Share Posted January 9, 2008 james69 said: Thanks Anguscanplay,It's the speaker with the chocblock connector. So it's best to give the installation firm a call because it's under a service contract.? James yes but dont let em charge you LOL nah as long as your sure its a speaker and that the cables are the correct ones stick it back together, I wouldnt be bothered but word of warning DONT LET THE GREEN AND WHITE TOUCH EACH OTHER AT THE ENDS while you decide what to do Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21855-scantronic-9651-sounder/#findComment-187962 Share on other sites More sharing options...
