philt Posted January 10, 2008 Posted January 10, 2008 A little help please. Came home to find my ADE Reson8 bell box sounder beeping roughly every 30 seconds. No faults showing on keypad. Panel is a Scantronic 9800 (vintage model 1995). As it was dark & chucking it down ended up disconnecting hold off supply & battery in the bell box to shut it up. Any ideas on the cause of said beeping much appreciated.
breff Posted January 11, 2008 Posted January 11, 2008 Check your battery connection in the main control panel, some old scanny panels used to make certain bellboxes beep if the battery was disconnected. Long shot.............. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
philt Posted January 11, 2008 Author Posted January 11, 2008 Check your battery connection in the main control panel, some old scanny panels used to make certain bellboxes beep if the battery was disconnected. Long shot.............. Thanks for that. Given the panel the once over, battery connections look OK but cleaned them up anyway. Reconnected everything and no beep fingers crossed!!!!
