9448+ Alarm Conrol Panel
Whoistheman
Hi,
I disconected the power to my 9448+ control panel whist carrying out some decorating and then left the power disconnected for several days. After reconnecting I have no power to the panel (no green line) and no power to any of the panels etc.
Any ideas what is wrong?
Knackered battery??
Blown fuses??
I thought the battery was only for back up, shouldn't the system run even if the battery is dead, clearly the battery must have run completely flat whist the power was off, but I should still get the green light to show there is power to the unit, no?
IMHO most likely scenerio;
you have turned power off to sytem thinking that would turn your alarm off - whilst decorating you have removed one or more of your sensors, as the panel was in fact still working (on the battery ie doing its job whilst power was off) , you have blown the auxillary fuse (small glass fuse on the pcb). Eventually the battery will have gone flat as well.
you need to check the glass fuses(replace the blown one with one of similar type/size), TURN MAINS OFF FIRST, and replace the battery as running a battery flat can damage its recharging ability.
IF YOU ARE AT ALL UNCERTAIN ABOUT TINKERING INSUDE THE CONTROL BOX DON,T - GET A ENGINEER IN.
then again i could be totally wrong :)
paul
THE BLACK KNIGHT
Guest anguscanplay
check your fuses are all okay first but think whats happening - your trying to restart a panel with a brick of a dead battery still connected ? the system just cant cope with all the power demands
fuses
battery off
power on
new battery (dont be tempted to use the old one)
here is my tuppence worthremove old battery, dispose of, in accordance with, local envirmental policiescheck for mains voltage* if present, switch off.* if not, check all fuses in 240v feed line, (be very careful mains kills)if all fuses ok then switch off 240v feed (for now)check all fuse on panels boardif ok follow, power up, procedure in accordance with panel instruction, using new battery.if not ok, replace blown fuses with correct size replacement (written in small print on the end caps of the fuses) then as above for power up..then let the fun begin B) let us know how you get on please.
agreed, most important.............
