soniarun Posted January 11, 2008 Posted January 11, 2008 I have moved into a house with a Scantronic 9651 alarm with six zones. The manual states you can set the alarm in silent mode (except on level A) , however it does not state how to set up silent mode and how to set up level B,C and D as part zones. Thank you in advance. arun soni
Guest anguscanplay Posted January 12, 2008 Posted January 12, 2008 I have moved into a house with a Scantronic 9651 alarm with six zones. The manual states you can set the alarm in silent mode (except on level A) , however it does not state how to set up silent mode and how to set up level B,C and D as part zones. Thank you in advance. arun soni thats because the`re engineer settings, one assumes the system isnt on a maintainance scheme, and you`ve tried the B,C or D settings as its unusual for the previous occupier not to have had it set up before. You`ll either need to reboot the system to clear the engineer code (assuming its been changed..) and reproggrame it or get an engineer in to do it for you
soniarun Posted January 16, 2008 Author Posted January 16, 2008 thats because the`re engineer settings, one assumes the system isnt on a maintainance scheme, and you`ve tried the B,C or D settings as its unusual for the previous occupier not to have had it set up before. You`ll either need to reboot the system to clear the engineer code (assuming its been changed..) and reproggrame it or get an engineer in to do it for you Thanks for your reply. Yes it is on maintainance agreement, its a new system. I will get in touch with installers. THANKS arun
