Optima XL6 still broke
Guest michelin
Guest michelin
:( I have tried all suggestions - thankyou all. Unfortunately the thing is still the same. I have replaced the PiR with new, checked all fuses, the control panel is not in tamper. I do not know the engineers code. The panel will now not show any lights bar the power light. My wife pressed the code then enter when she initially got the control board out of tamper mode. If I need a new box, can someone please advise on a replacement.
Guest michelin
Yes, I have tried this code and #### and #### etc but the panel just keeps on making noises.
Guest lev
Try removing the mains power and back up battery. Then reconnect mains power only and enter user code when alarm sounds. Alarm should stop, if not try 0123. Replace battery and lid if all is well. You should be left with power light on and day light on. If this dosnt work do an NVM reset. If that dosnt work nothing will. Optima G3 is the nearest equivalent panel, very reliable.
Time for the professionals I reckon.
Ditto
Get your local installer to replace it with a Optima G3. A good quality panel with loads of features for a reasonable price.
Good luck
Let us know how it works out.
Dave
