patwilson Posted January 14, 2008 Posted January 14, 2008 Hi, I have an optima XM house alarm. Just recently a fuse in the box keeps blowing. These are the 1.6 amp clear glass fuses (quick blow) and it's the left hand side fuse as you look into the box. I keep changing the fuse and then it's fine for maybe a weeks, a day or just hours, then it just blows. Does anyone know why it might be doing this???? the system is 15 years old but was only serviced last year and put new battery on etc. At the moment i am changing the fuse myself as last call out was
antinode Posted January 14, 2008 Posted January 14, 2008 Can't remember off the top of my head, but I think the left hand fuse is for the Aux supply (ie power to detectors/bell) with the right hand one being for the battery. The reason this fuse is blowing is because something on the system is drawing too much current (could be a faulty PIR/Bell, damp in the bell box connections or cable fault etc). Unless you know how to check for this (you need a multi meter), you may need someone in to sort it for you. Throwing fuses at it is not really doing it any good You had any carpet fitters/building work done recently?! Trade Member
advancedprotection Posted January 14, 2008 Posted January 14, 2008 the external bell may have dampness in the connections causing it to short out and blow the fuse. Trade Member It's nice to be important but it's more important to be nice!! Martin Hanfo CCTV - Intruder Alarms - Access Control - Security Lighting - Locks Covering South Wales 07903 967045
magpye Posted January 14, 2008 Posted January 14, 2008 Can't remember off the top of my head, but I think the left hand fuse is for the Aux supply (ie power to detectors/bell) with the right hand one being for the battery. The reason this fuse is blowing is because something on the system is drawing too much current (could be a faulty PIR/Bell, damp in the bell box connections or cable fault etc). Unless you know how to check for this (you need a multi meter), you may need someone in to sort it for you. Throwing fuses at it is not really doing it any good You had any carpet fitters/building work done recently?! That fuse is the Bell & Strobe fuse - 1.6Ah 20mm The right hand fuse is the Battery fuse, same size Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
inglishg Posted January 14, 2008 Posted January 14, 2008 Is your bellbox as old as the rest of the system? Does the fuse only blow after the alarm has triggered? I'm thinking that if you've got a c-type bellbox with an external strobe, then I've had many strobes cause such a draw on the supply that they've popped the fuse. Might be worth disconnecting the strobe to isolate the problem. It does need sorting though. Get proper help - that
kka Posted January 15, 2008 Posted January 15, 2008 how about going the full mile, and getting a new one this old one, has already cost you Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
