GrahamUK33 Posted January 14, 2008 Posted January 14, 2008 I read that the Texecom Prestige AMQD Plus PIR has Triple End-Of-Line (T-EOL) signalling (not sure what that is), will this be compatible with the Texecom Premier 24 control panel or will I have to go for the Texecom Premier 48 control panel? Graham twitter: ithorizon1 http://www.ithorizon.co.uk
Rulland Posted February 25, 2008 Posted February 25, 2008 I read that the Texecom Prestige AMQD Plus PIR has Triple End-Of-Line (T-EOL) signalling (not sure what that is), will this be compatible with the Texecom Premier 24 control panel or will I have to go for the Texecom Premier 48 control panel? Hi, triple end ofline is used for signalling a pir 'masked' condition-you can fit it to any panel-just dont use the triple teol function-ie the fault contact on the PIR-if it's not required.
