Galaxy G2-20 Plastic Enslosure
Dabsbhatti
Guest anguscanplay
Can the backup battery be 2 x 12V 7Ah connected in parallel.
why ?
I think the g2-44 plastic enclosure requires a 12V 7Ah battery and the metal enclosure 12V 14Ah. So if I don't have a 14Ah but I do have 2 x 7Ah. Ok its not ideal but should do the trick shouldn't it. Also any idea why the metal enclosure requires a bigger battery?
Guest anguscanplay
you sure thats not the maximum size it will take - nothing actually requires anything on its own, only to comply with regs etc
if thats the case dont worry about it just fit one 7amp
