Panel Identification
beemer
I have just moved to a new office and want to change the alarm panel code, landlord says he was left no manual!!
I cannot identify the panel & the engineers code is unlocked additionally I took the front off and now have a 1701 tamper panel error
Can anyone please help :rolleyes:
TIA
TonY
TIA
TonY
The panel is a DA Abacus. Make sure the lid is fitted correctly with both screws. Now enter the code system should say "set system?" push yes. The systm should start to set enter the code again and now the system should be reset. If this doesn't work the system will be engineer reset.
