Galaxy G2-44 Line Failure
Herman
I've got a G2-44 in a domestic.
It is set up for SMS texting (no monitoring).
The panel momentarily dropped into line failure this morning (several BT vans spotted up the road).
As a consequence the panel demands a manager reset.
The customers are elderly and each have their own personal PIN.
Neither have any knowledge of a master code, nor do they comprehend the concept of master/manager/user codes.
Was just wandering if there's any way of disabling manager reset for line failure.
I'm trying to avoid raising their user code status to manager/master.
nope it will always need a manager reset
It will always call for a reset for line fail but you can switch off line monitoring - not a problem if its not a requirement.
Fail to communicate is fun too, it keeps asking for a reset until it next successfully sends an SMS text - set to text on 'alarm only' it could be like that for months!
  • 2 months later...
An engineer restart will also clear the SMS Comms Fail
  • 9 months later...
Great fun - engineer attendance just because it fails to send a text on an audible system!
We currently have a G2-44+ installed and are having dificulty setting it up for SMS only could you elaborate on the steps required to do this.
Any help would be appreciated.
