cedric2 Posted January 16, 2008 Posted January 16, 2008 Hi, I have a stupid question, I don't find the answer on the manual. Can I check the status of the zones (to check of all the doors/windows was close) just in look at the remote LED pannel, without activate the alarme. (With others words, does the zone LED was illuminate, if the zone was open, even in standby mode) If the veritas don't have this fonction, do you know if others remote pannel have with this fonction ? Regards, Cedric
kka Posted January 17, 2008 Posted January 17, 2008 no in short, but what is your thinking behind wanting this done... Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
cedric2 Posted January 17, 2008 Author Posted January 17, 2008 Hi, I can't see my garage door from inside the house, and I want to use the alarm remote pannel to check if the garage was open or close. (quite often my children forgot to close it) I allready have all the connector needed from my actual old alarm. regards cedric
FASTCAR Posted January 17, 2008 Posted January 17, 2008 When you attempt to arm the panel , any zones in fault ( open ) will be illuminated. So if you system is set for one button arming and you want to check the garage doors without arming the alarm , you press FULL , any open zones are displayed , press RESET to clear the display.
kka Posted January 17, 2008 Posted January 17, 2008 have you thought about a cctv. not only could you see if the door was open, but you could also see your drive way, and kids of course... they may well be somebody else with another feasible solution. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
