Drahcir Posted January 23, 2008 Posted January 23, 2008 someone's been trying to sell me LED lighting for security because apparently the colour rendering is really good - ie. Rather than being able to see if someone is wearing a 'dark' coat, you can see exactly what colour it is. They've also told me that it can be switched on and off instantly like a halogen using a pyro but only uses 35w for the same light output as a 150w halogen and is low voltage (24v) meaning i can use very light weight wiring. Frankly, this sounds too good to be true to me. Has anybody here used this kind of lighting before? If so, was it any good? Thanks
daveboy Posted January 23, 2008 Posted January 23, 2008 someone's been trying to sell me LED lighting for security because apparently the colour rendering is really good - ie. Rather than being able to see if someone is wearing a 'dark' coat, you can see exactly what colour it is. They've also told me that it can be switched on and off instantly like a halogen using a pyro but only uses 35w for the same light output as a 150w halogen and is low voltage (24v) meaning i can use very light weight wiring.Frankly, this sounds too good to be true to me. Has anybody here used this kind of lighting before? If so, was it any good? Thanks Its true led is the future.
arfur mo Posted January 23, 2008 Posted January 23, 2008 i don't know if all the claims ring true, i've used 2 x high power led units with good effect, but can't say ot improved object colour. the requirement was for IR, these units cost If you think education is difficult, try being stupid!!!!
arfur mo Posted January 23, 2008 Posted January 23, 2008 www.rayteccctv.com pro-opticam was my supplier regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted January 23, 2008 Posted January 23, 2008 someone's been trying to sell me LED lighting for security because apparently the colour rendering is really good - ie. Rather than being able to see if someone is wearing a 'dark' coat, you can see exactly what colour it is. They've also told me that it can be switched on and off instantly like a halogen using a pyro but only uses 35w for the same light output as a 150w halogen and is low voltage (24v) meaning i can use very light weight wiring.Frankly, this sounds too good to be true to me. Has anybody here used this kind of lighting before? If so, was it any good? Thanks for cameras or just "lighting.."?
arfur mo Posted January 24, 2008 Posted January 24, 2008 for cameras or just "lighting.."? i'm as assuming for CCTv, due to reference to rendering and seeing colour . btw hows the googling coming along? while they are at it (the sproggs) could they please find anything on the dangerous practice of using neon screwdrivers please - your a pal ) regs alan If you think education is difficult, try being stupid!!!!
CCTV_SUPPORT Posted January 24, 2008 Posted January 24, 2008 I can recommend the Raytec products after using them. Going to a seminar held by them in a few days, regarding IP cameras and Infrared lighting.
