Intermittent Tamper
Guest rhodesmi
Guest rhodesmi
Hi, 5 years ago I installed a Veritas Alarm for my in-laws and forgot it came with a lifetime labour and parts warranty.
The latest fault is an intermittent alarm due to Tamper. I thought this would be straight forward to fix by wiring out half of the tamper cicuit to find which half was causing the tamper but even if I install a link between the 2 Tamper terminals on the PCB it still goes off intermitantly.
I have checked the 12V rail which is OK. I have re-set the alarm and performed a total power off/power on.
Am I missing something obvious?
cheers in advance.
Guest rhodesmi
Thanks to Dave Partridge also for pointing out the bellbox tamper (I have posted this question in more than 1 place oops)
I thought I only had 1 tamper circuit, I will check this out and get back to you.
