graham99114 Posted January 24, 2008 Posted January 24, 2008 looking to add an external G-TAG reader to the remote Key Pad of a gardtec 490X the wires on the end of the cable from the reader are coloured white / red / yellow / black / blue / Green the instructions state (for a cable length < 7.5m) that RED goes to SET BLUE goes to ANT YELLOW goes to ANT BLACK goes to OV but the terminals labelled on the RPK are labelled Terminal Block 2 A1 A2 Terminal Block 1 A3 A4 SET D2 D1 0V 12V ZONE the red to SET and black to 0V are straight forward - but where do the BLUE and YELLOW go ? Any Ideas
graham99114 Posted January 25, 2008 Author Posted January 25, 2008 looking to add an external G-TAG reader to the remote Key Pad of a gardtec 490Xthe wires on the end of the cable from the reader are coloured white / red / yellow / black / blue / Green the instructions state (for a cable length < 7.5m) that RED goes to SET BLUE goes to ANT YELLOW goes to ANT BLACK goes to OV but the terminals labelled on the RPK are labelled Terminal Block 2 A1 A2 Terminal Block 1 A3 A4 SET D2 D1 0V 12V ZONE the red to SET and black to 0V are straight forward - but where do the BLUE and YELLOW go ? Any Ideas managed to find out BLUE&YELLOW GO TO A1 & A2 RED goes to SET BLACK goes to OV
Guest anguscanplay Posted January 25, 2008 Posted January 25, 2008 managed to find out BLUE&YELLOW GO TO A1 & A2 RED goes to SET BLACK goes to OV was it the instruction manual gave it away ?
graham99114 Posted January 25, 2008 Author Posted January 25, 2008 nope - instruction manual details were as per in first post - eventually got the info for the supplier technical help line
