secure2007 Posted January 25, 2008 Share Posted January 25, 2008 hi there i have a dvr in the next room which records cctv around the house but you can plug in an ethernet cable in the back of it and connect it to the computer so i can view and record the cameras on the computer with the software it come with. so i brought a 100m cat5e network cable, rj45 connectors and a crimp and made a 5 meter long straight through cable and connected it to the dvr and the pc but nothing happend. so i then created a crossover cable and connected it and it started to connect then it came up with limited or no connectivity. i keep trying to reset the dvr but same message keeps on coming up what am i sposs to do as in the user manaul thier is information on only static IP, dynamic IP and dynamic IP of PPPoE (dsl). on the dvr thier is a ethernet port on the back which i have currently connected the crossover network cable to. and in the dvr menu there is a section on TCP/IP setup. Could some help me as soon as possible as it is very essential to get this working asap. Link to comment Share on other sites More sharing options...
breff Posted January 26, 2008 Share Posted January 26, 2008 You need to use the crossover cable if going direct from dvr to pc, manually assign both machines an address in the same range and give them both the same subnet mask. (try 192.168.1.1 and 192.168.1.2 with subnet masks of 255.255.255.0) The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
secure2007 Posted January 26, 2008 Author Share Posted January 26, 2008 yes i have assigned both the computer and dvr with the same IP, subnetwork, defult gateway but still the computer comes out with limited or no connectivity Link to comment Share on other sites More sharing options...
arfur mo Posted January 26, 2008 Share Posted January 26, 2008 yes i have assigned both the computer and dvr with the same IP, subnetwork, defult gatewaybut still the computer comes out with limited or no connectivity with respect, as you actually made the lead are you sure it is ok and the correct wiring was used? if you have a hub or router simply use straight patch leads to test all else is well with the rest of the setup regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
secure2007 Posted January 26, 2008 Author Share Posted January 26, 2008 i used this website to make the crossover cable http://www.duxcw.com/digest/Howto/network/cable/cable5.htm and i brought a cat53 network cable from amazon Link to comment Share on other sites More sharing options...
amateurandy Posted January 26, 2008 Share Posted January 26, 2008 with respect, as you actually made the lead are you sure it is ok and the correct wiring was used?if you have a hub or router simply use straight patch leads to test all else is well with the rest of the setup regs alan Yup, beg steal or borrow known working hub, switch or router and patch cables. Most units have lights on so you can see if the cable is plugged in and "working" (sort of). Router is best as it'll assign IP addresses for you via DHCP. And some devices are auto-sensing so don't mind if cables are straight or crossover either! Once you've got that working move to your own cable...... Link to comment Share on other sites More sharing options...
DavetheDrunk Posted January 26, 2008 Share Posted January 26, 2008 does it ping? Link to comment Share on other sites More sharing options...
secure2007 Posted January 26, 2008 Author Share Posted January 26, 2008 the lights nexto the ethernet port on the back of my conputer lights up and flashes its a green light. i cannot get a router or a hub as i dont know anyone with one how can i check if it pings mate? Link to comment Share on other sites More sharing options...
DavetheDrunk Posted January 26, 2008 Share Posted January 26, 2008 the lights nexto the ethernet port on the back of my conputer lights up and flashes its a green light. i cannot get a router or a hub as i dont know anyone with onehow can i check if it pings mate? from dos prompt, ping then its ip addy Link to comment Share on other sites More sharing options...
camerabloke Posted January 26, 2008 Share Posted January 26, 2008 as Breff says address the PC to a slightly different IP address ie 192.168.1.1 for the dvr and 192.168.1.15 for your PC try and behold!!!!! Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
