arfur mo Posted January 26, 2008 Share Posted January 26, 2008 i used this website to make the crossover cable http://www.duxcw.com/digest/Howto/network/cable/cable5.htm and i brought a cat53 network cable from amazon you should be using the EIA/TIA 568B drawing, but trust me here crimping down RJ45 cables it is easy to accidentally cross over cables or get no connection at all on one or more cores, and this is down to either the user inexperience or the often cheapy crimping tool used. if you don't have the test kit you can buy a crossover pre built patch lead or a crossover built into an RJ45 to RJ45 through connector from maplins, then use 2 x standard pre made patch leads, and tbh i'd suggest this is the way for you to go. regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
secure2007 Posted January 26, 2008 Author Share Posted January 26, 2008 right i ping 192.168.1.6 and it came as sent 4 and recieved 4. i have set 192.168.1.6 for the computer and 192.168.1.5 for the dvr. but it still not working. right now when i double click on the network icon for that it says connected but the packets sent is 50 and recieved is 0 Link to comment Share on other sites More sharing options...
justin Posted January 27, 2008 Share Posted January 27, 2008 There is proberbly a bit more to it. Assuming your physical connections have been made correctly. Have you setup the DVR software correctly, there will be a setup/configuration screen, display options etc. What DVR are you using? Justin Link to comment Share on other sites More sharing options...
camerabloke Posted January 27, 2008 Share Posted January 27, 2008 please dont say mpeg 4! Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
secure2007 Posted January 27, 2008 Author Share Posted January 27, 2008 DYN 8 JPEG2000 Link to comment Share on other sites More sharing options...
arfur mo Posted January 27, 2008 Share Posted January 27, 2008 DYN 8 JPEG2000 i suggest you contact their tech help regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
secure2007 Posted January 27, 2008 Author Share Posted January 27, 2008 thanks will try and find thier contact details tomorrow and phone them Link to comment Share on other sites More sharing options...
sjonley Posted February 9, 2008 Share Posted February 9, 2008 A hub and standard network cables will save you no end of grief than trying to use a crossover cable. See a pc supplier www.scan.co.uk as a good source for a small 5 port 10/100 hub (apprx Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk Link to comment Share on other sites More sharing options...
barooga Posted February 9, 2008 Share Posted February 9, 2008 A hub and standard network cables will save you no end of grief than trying to use a crossover cable. See a pc supplier www.scan.co.uk as a good source for a small 5 port 10/100 hub (apprx Growing old is mandatory, growing up is optional Link to comment Share on other sites More sharing options...
sjonley Posted February 9, 2008 Share Posted February 9, 2008 Why? Because for a decent hub from PC World will cost you 50-100% more than other smaller suppliers. How do you think they subsidise all the TV adverts they have? Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk Link to comment Share on other sites More sharing options...
