A Question.... Would This Work?
helimatt
Nice to see someone looking help getting the usual "help" :rolleyes:
Flaw in the idea using a 3G USB unit is the fact they will not allow streaming on any network
So my "could work" becomes a NO, it won't work.
:closed:
Arfur & Angus can go and play elsewhere now. :mf_swordfight:
Complete nonsense!
The post was a wind up. Everytime questions were asked the problem changed. This was definitely not to hide the job.
Give us all some credit Arfur.
and i do honest, just you lot don't make it so easy to do that sometimes :P
regs
alan
Guest anguscanplay
:closed:
behave IT geek, I`m the only one not deliberatly winding the O/P up
Guest anguscanplay
Ahem! Nor me.
PS Use a spell/grammar checker. :rolleyes:
its not me, its the laptop - wouldnt load the spellchecker
the o/p imo is being vague in order (i'd assume) not to give away either the job details or the site location as either a respect of confidence to his client, or understandably to protect his own commercial interests. lets face it, we are not the only 'sado' people who read these posts.
so lets just accept he can't divulge the true scenario, and so has done his best to conjure up a comparison situation in order to explain what he needs.
Makes sense to me :yes:
i don't want to hi jack this thread, but i'm pondering a simular problem for a current job, so discussing it might help the o/p question and me.
scenario
block of 10 flats on 3 levels, has a central riser, kit is a SYSQ 365 DVR.
i can't run cable inside the flats due to decor problems.
question - can i attach say three Wifi access points (1 per floor) into a switch, and then hook the switch into the DVR RJ45 port?
i can easily cable the access points into the riser, but will this arrangement let the flats access the dvr from their pc via wireless link (assuming range is ok)?
regs
alan
Hi Alan.
To attach the DVR365 to wireless LAN just buy a
System Q Ltd.
Hi Alan.
OK GUYS.....
I AM A POLICE TECH OFFICER AND WAS AFTER A LITTLE HELP.
I APOLOGISE IF MY POSTS WERE A LITTLE HAZY, ALTHOUGH I THOUGHT YOU MAY HAVE RESPECTED MY RIGHT TO APPLICATION CONFIDENTIALITY.
I HAVE SUBSEQUENTLY FOUND A SOLUTION TO MY PROBLEM - EASIER THAN YOU WOULD IMAGINE, AND AM VERY SUPRISED NO ONE HERE HAS MENTIONED.
MANY THANKS FOR YOUR INPUT GUYS.
BEST REGARDS
MATTHEW
