I'm trying to fix or replace components of a faulty 4-zone "Tate Fire and Security" fire panel. The panel now always registers "fire" on one of the zones. Internally, the main PCB is marked "1990 Securitech" and "T-S4/90". There are separate plug in cards for each of the 4 zones. It appears that it is one of the plug-in cards which is at fault as if I swap them round, it is always the same one that fails.
Does anyone knows of a supplier of replacement "zone" cards? It appears that "Tate Fire and Security" have gone out of business (or perhaps they are now part of Tate Colson?)
Ideally I would like to track down a circuit schematic to try to diagnose/fix the problem myself, though if anyone knows what is typically the source of such a failure, please reply. The zone card itself is a fairly small circuit with only 2 ICs: MC14011B (Quad 2-input NAND logic) and LM339 (Quad Voltage Comparator).
Regards,
Richard
  • 1 year later...
Posted (edited)
I have just come across the exact same make and model,
Did you ever find a manufacturer?
I need the display PCB, if anyone has one.
Alternatively I guess it means I may have a zone card for you, although I realise your post was a while back......
Bill
Edited by Pyromaniac
I once had a boss who when the District surveyor said there are not enough Decibels in the Boiler room, told me to get some out of stores.
I used to deal with Tate a good few years ago and had not realised they had gone squit.
They did not manufacture. They re-branded many different manufacturers systems.
What panel is it? It may be a conventional type which uses generic bases which can be used with oodles of other panels.
Email : martin@askthetrades.co.uk
securitech were made in redditch. Later became c&k securitech. Made fire panels until the mid 90's id say in redditch uk.
Then got swallowed up c&k and production stopped, then bought by honeywell.
Unless someone has an old one then id suggest its bin time. But to be fair 4 zone basic conventional fire panels are less than
  • 10 years later...
Hi, did you ever sort this? I need a zone card! Or wiring diagram, let me know pleaseĀ
thanks
Quote
Regards,
Richard
D
Hi: The post you replied to is some 10 years old now, so doubt you'll get a response.
Panel schematics were never issued to the trade by manufacturers only Installer and user manuals, if your trying to repair the panel for re-use you could be leaving yourself open to prosecution if it fails in the event of a fire.
