Alarm Co Posted February 7, 2008 Posted February 7, 2008 has anyone heard of sl dialer? had to work on panel today with said dialer fitted but owner wanted numbers changing in dialer but was a bit stuck any help would be great
Monty Posted February 7, 2008 Posted February 7, 2008 Menvier did an SD1 Diller now SD2 or 3 you can down load info at www.coopersecurity.co.uk quite easy to use but you had to get the 8 tone for conformation twice just at the correct time to cancell down . www.AllanMoncrieffAlarms.com
Alarm Co Posted February 7, 2008 Author Posted February 7, 2008 yes i fit sd1+ now but im looking for sl dialer
arfur mo Posted February 7, 2008 Posted February 7, 2008 has anyone heard of sl dialer?had to work on panel today with said dialer fitted but owner wanted numbers changing in dialer but was a bit stuck any help would be great is that actually a tunstal SD1? grey square box with keypad and LCD if so, you hold the enter key in bout 5 seconds until the display changes, i think to change the numbers to be dialed press 1, 2 Or 3 for which number you want to change. '0' to change main address message, and/or A, B or C for the channel message as relevant. i think thats the right way round, been a while since i done one, but display will tell you anyway regs alan If you think education is difficult, try being stupid!!!!
Alarm Co Posted February 7, 2008 Author Posted February 7, 2008 alan it did say sl dialer on front but it does sound as you discribed lcd display , three green leds down side of display with numerical keypad under the display then ??? reset, call , test , record , buttons underneath that? does sound like it alan??
arfur mo Posted February 7, 2008 Posted February 7, 2008 alanit did say sl dialer on front but it does sound as you discribed lcd display , three green leds down side of display with numerical keypad under the display then ??? reset, call , test , record , buttons underneath that? does sound like it alan?? no not really, but might be a later version before the SD2 came out perhaps? the one i know has SDI printed on the left side, also has ESC and ENT keys on th e bottom row, so seems like you have one i've not seen. suggest post a piccy perhaps someone will recognise it. regs alan If you think education is difficult, try being stupid!!!!
Alarm Co Posted February 8, 2008 Author Posted February 8, 2008 Like this ... yerrrrrrrrrrrrrrrrr u guys never fail w,t, f is it ???
luggsey Posted February 8, 2008 Posted February 8, 2008 yerrrrrrrrrrrrrrrrru guys never fail w,t, f is it ??? Says Honeywell on the lid..... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Alarm Co Posted February 8, 2008 Author Posted February 8, 2008 Says Honeywell on the lid..... well it aint on securitywarehouse.co.uk
