PYRONIX PIR
Guest WRPGH02
Guest WRPGH02
CAN ANYONE HELP AS I AM TRYING TO CHANGE FROM OLD BROKEN PIR TO A NEW MERCURY EL-400 BUT THE WIRING HAS 6 TERMINALS ON THE PYRONIX BUT THERES 8ON THE NEW MERCURY EL-400 SO AS I DONT HAVE MANUAL FOR THE PYRONIX MAGNUM EP I DONT KNOW WHICH GOES WHERE AND THE ALARM MANUALSNO GOOD AS SUCH.
MANY THANKS IN ADVANCE
This should do the trick
1 & 2 = Tamper
3 = positive
4 = negative
5 & 6 = Alarm zone
And here`s the instructions for a DL100, same unit though.
This image might take a while to load as its nearly 100KB.
Guest WRPGH02
THANKS BUT I HAVE NEW MANUAL FOR THE mERCURY EL-400 ITS THE WIRING DIAGRAM FOR THE OLD ONE THE pYRONIX MAGNUM EL I NEED SO I CAN KNOW WHICH WIRE FROM THE OPTIMA 2 PLUS GOES....i HAVE WRITTEN DOWN WHICH WIRE WENT WHERE SO IF I CAN FIND OUT WANT THEY WHERE I CAN TRANSPOSE TO THE NEW ONE :) i THINK ANYWAY.....I DIDNT EXPECT THE OLD MANGUM EP TO NOT HAVE ANY MARKINGS ON IT AS TO WHICHCABLE WAS WHAT?????
ANY IDEAS
MANY THANKS
Guest honz
did the old pir not have indication on the pcb what each terminal was for
e.g. (my company colour code)
where you took the red out it had written above it 12v and black 0v or Grd etc.....
That`ll teach me to read the posts a 2nd time, just wasted 15 minutes searching the web for that info...:(
Guest WRPGH02
HONZ
I HAVE THIS ON THE OLD PCB
T T N / C - + AND THIS CORSPONDS TO THE WIRES THAT WHERE AS FOLLOWS
YELLLOW/BLUE/GREEN/WHITE/BLACK/RED
BUT WHERE DO THIESE CABLES GO O THE NEW ONE ...ALSO I PUT THE +/RED TO THE +VIN ON THE NEW PIB... BLACK/- TO THE GND ON THE NEW ONW...GREEN/ N
TO THE TAMP(TERM 1) ON THE NEW ONE .... WHITE/ C TO THE NC (TERM 2) ON THE NEW ONE....YELLOW/ T TO THE RLY (TERM 5)....BLUE/ T TO NC (TERM 6) ON THE NEW ONE......THIS DOES GET RID OF THE TAMPER FAULT ON THE ALARM AND IT GOES TO DAY OK BUT IT THEN IS STILL ACTIVE (THE PIB) AND SETS THE ALARM OFF AGAIN...
SERVICE ENGINEER SORRY YOU HAD TO SEARCH WEB AND MANY THANKS FOR DOING SO .... BEST REGARDS
the terminals marked t are the tamper pair, the terminals marked nc & c are the alarm pair and + & - are self explanatory
youve got the green/white pair round the wrong way with the yellow/blue pair swap them over
Guest WRPGH02
BREFF CAN YOU GIVE ME A DIAGGRAM WITH WHICH COLOUR WIRE AND WHERE IT SHOULD GO ON THE NEW PIB PLEASE....BE VERY GREATFUL....MAYBE WHERE ALMOST THERE????
MANY THANKS
