johnnyrotten Posted February 10, 2008 Posted February 10, 2008 Ime looking for a day night camera with perfect {or near enough} resolution, that can read number clearly from about 10 to 20 metres, what should i be looking for spec wise ? big lens more lines ime stuck again.
Guest anguscanplay Posted February 10, 2008 Posted February 10, 2008 10 or 20 meters ? - your going to need to decide which first
Service Engineer Posted February 10, 2008 Posted February 10, 2008 12mm lens, 420tvl + ........................................................ Dave Partridge (Romec Service Engineer)
sjonley Posted February 10, 2008 Posted February 10, 2008 depends what your trying to read. is it numberplates? predominantly day time, nightime or both. If its general viewing I would always go with a high res day / night, ex-view chipset and moveable ir cut filter. If your trying to get numberplates a proper number plate capture camera is best but they can cost a thousand to many thousands of pound. As a rule of thumb, numberplate capture should be 50% rotakin or better or 2m target width. Try this quick calculation for determining focal lengths: Focal Length = (Chip size x distance to target) / Target width chip sizes are: 1/3" = 4.8, 1/4 = 3.6 In your example, on a 1/3" chipset and 2m target width would be: at 10m: (4.8 x 10) / 2 = 24mm focal length at 20m: (4.8 x 20) / 2 = 48mm focal length a 5-50mm varifocal lens should be adequate. Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk
johnnyrotten Posted February 11, 2008 Author Posted February 11, 2008 Thank fer that ime lookin on the net fer a 12mm cam with about 450tvl....
Guest anguscanplay Posted February 11, 2008 Posted February 11, 2008 Thank fer that ime lookin on the net fer a 12mm cam with about 450tvl.... so you dont want to read number plates then ?
