Cuchullian Posted February 15, 2008 Posted February 15, 2008 Hi fitted this alarm for an elderly couple but the keypad sounder is too low for them to hear and i want to fit an additional piezo sounder for added volume. Rang the company , cost me
ViperMK2 Posted February 15, 2008 Posted February 15, 2008 Add a 16 ohm speaker and connect it to the control panel, that will do the trick. As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
Cuchullian Posted February 16, 2008 Author Posted February 16, 2008 Add a 16 ohm speaker and connect it to the control panel, that will do the trick. Thanks , at last something I can actually do.
Guest anguscanplay Posted February 16, 2008 Posted February 16, 2008 Thanks , at last something I can actually do. it is in the instruction manual you know !
Cuchullian Posted February 16, 2008 Author Posted February 16, 2008 it is in the instruction manual you know ! , found it but wasn't sure if this worked on entry/exit mode. Thanks for your help.
Guest anguscanplay Posted February 16, 2008 Posted February 16, 2008 , found it but wasn't sure if this worked on entry/exit mode. Thanks for your help. thats the problem (it should have been fitted anyway for false sets etc) - it replicates ALL the keypad tones turn the volume pot right down and it helps with part set tones but its a notorious panel for been too loud (and I`m deaf !!!)
Cuchullian Posted February 16, 2008 Author Posted February 16, 2008 thats the problem (it should have been fitted anyway for false sets etc) - it replicates ALL the keypad tonesturn the volume pot right down and it helps with part set tones but its a notorious panel for been too loud (and I`m deaf !!!) Once again your advice is appreciated and very helpful as the intellisense helpline was a con , just after a very premium rate of
ViperMK2 Posted February 16, 2008 Posted February 16, 2008 Turn the volume pot right down and it helps with part set tones but its a notorious panel for been too loud (and I`m deaf !!!) 'Chime' anyone It will let everyone in the neighbourhood know when you open the door. As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
Guest anguscanplay Posted February 16, 2008 Posted February 16, 2008 'Chime' anyone It will let everyone in the neighbourhood know when you open the door. ahh the good old 700/800L - coming to a housing estate near you soon - thing is for something so cack they must have sold millions of them
Cuchullian Posted February 16, 2008 Author Posted February 16, 2008 ahh the good old 700/800L - coming to a housing estate near you soon - thing is for something so cack they must have sold millions of them So what would you recommend as my mate has been fitting these for years from the wholesaler and has found them to be very reliable. Surely thats what's important Price , quality and reliability ???????
