BobClarke Posted February 15, 2008 Posted February 15, 2008 Hi All, Anyone hade the following fault before ? On a large site we have scan 8136 i. Every now and again the keypad comes up with "invalide " when a fob is presented to it. I then need to reprogram the fobs back into the system. It's driving me mad !! There is no induced ac. Could the idis board be stuffed ? Reg Bob.
Guest anguscanplay Posted February 15, 2008 Posted February 15, 2008 Hi All,Anyone hade the following fault before ? On a large site we have scan 8136 i. Every now and again the keypad comes up with "invalide " when a fob is presented to it. I then need to reprogram the fobs back into the system. It's driving me mad !! There is no induced ac. Could the idis board be stuffed ? Reg Bob. every fob or just the same one over and over again?
BobClarke Posted February 16, 2008 Author Posted February 16, 2008 every fob or just the same one over and over again? Hi M8, It is not the same fob all the time, only happens now and again. It seems random. About three or so. Reg Bob.
Guest anguscanplay Posted February 16, 2008 Posted February 16, 2008 Hi M8,It is not the same fob all the time, only happens now and again. It seems random. About three or so. Reg Bob. we seem to be always re-progging fobs for people (gardtec in our case) the technology just doesnt work IMO
arfur mo Posted February 16, 2008 Posted February 16, 2008 we seem to be always re-progging fobs for people (gardtec in our case) the technology just doesnt work IMO can't say i have ever had problems with gartec g-tags, used be a bit iffy on the ir fobs though. new 4 wire keypads you only need to prog g-tags in at one kekypad then they work on all of them - hooray! this is gonna sound daft, is there a memory protect link in the scanny keypads? if so has it been removed? regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted February 16, 2008 Posted February 16, 2008 can't say i have ever had problems with gartec g-tags, your just not doing them in enough numbers to notice
Monty Posted February 26, 2008 Posted February 26, 2008 Have not used in large numbers the scantronic fobs(mainly domestic with 2/3 fobs on system ) but put in an M1000 with 50 fobs and did have 3/4 that didn't work all the time some worked at the keypad but not on remote AX10 reader ? replaced and used on other site that only had key pad and worked ok . what we did find that if the user had had a problem and had not reset the system properly then he would have a problem from the remote reader, but that was not the problem with the 3/4 that we had problems with. www.AllanMoncrieffAlarms.com
