Bell Box Problem When Heavy Frost
chrishewer
Hi,
Anyone able to give me some advice?
During the early hours when there was a heavy frost one of my two bell boxes (Tate) of my intruder alarm (Melcom) started intermittently sounding for short bursts (few secs max) in no regular pattern. It went on for a few hours and now it has stopped - ?starting to warm up?.
I tried putting the alarm on engineer setting, however despite this it continued to sound.
I assume that it must be a local fault in the bell box which hasn't triggered the tamper loop. What is the likely problem in your experience?
Thanks
Chris
Guest anguscanplay
tate ? sounds like Risco made to me possibly
you`ll need to fit a link (details are in the instruction sheet)
if not there just old and got water damaged and will need changing IMO
Points to a intermittent positive feed at the sounders PCB board, looks like the laddders are coming out!
sounds like lid tamper opening and closing
maybe due to cold warping lid or metal spring on tamper
activating sab
did panel show a tamper
Hi,
Thanks
Chris
get a tin of pcb laquer )spray) and coat the pcb's, bought from rs components or maplins.
regs
alan
as above, risco sounders had a fault a while back. if it drops below -6 the sounder will chirp.
Guest anguscanplay
had the very problem this morning
Guest anguscanplay
i had loads, was a real PITA that one.
and it was minus 4 degrees too when I set off (and dark)
