C&k Securit 800l+ - Quiet Arming Sound?
Quartz
How loud are we talking and where from. Is it only the keypad sounding or is the speaker just quieter. if it's only the keypad sounding then maybe a bad connection on the speaker terminals in the panel or at the speaker, if it's a quiet speaker then maybe you have turned the volume pot down in the panel.
As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
The latter. I'm actually quite happy with the lower noise per se, I'm just concerned that it might be an indicator of a fault.
Guest anguscanplay
get it checked
800l with a dodgy loudspeaker piccy
get it checked
Thanks - I'm sure I would have spotted that but I'll check it again tomorrow (during daylight).
Guest anguscanplay
thats after the fire, not why the sounder went quite - what resistance reading do you get across the speaker cable
I don't have a multimeter to hand to test it. Before, the interior bell was easily audible through the front door when arming. Now it's just audible.
Guest anguscanplay
get it checked - now
if you havnt got the tools then get someone in to do it, there IS a real and present fire risk to this kind of fault
