Gardtec Alarm Zone Attributes
valks1
its an advice forum - let me give you some, when your wrong shut up, stop trying to dig yourself out of the hole,just admit it and move on to the next topic - its for the best
the (9) is as a reminder still says 'normal' OR eol on selection, but no matter lets ask was the o/p asking about masked detection or the values? did the o/p even have detectors capable of detecting if they are masked? idf so which type i.e. transistor or relay output
your not adverse to dragging me or others back to comments in past unrelated posts - so i thought i'd just pay back the compliment to you, while we are at it and passing the time of day, so how will loopng out a zone at the panel with a link disable a zone on an en eol system?
that will be caught out then and just to embarrassed to answer properly?
regs
alan
Guest anguscanplay
the (9) is as a reminder still says 'normal' OR eol on selection, no it doesnt the option cycles through NORMAL then ELF1 then ELF2 - not NORMAL then EOL then PINK PYJAMAS - your wrong just have the grace to admit it and MOVE ON
but no matter lets ask was the o/p asking about masked detection or the values? did the o/p even have detectors capable of detecting if they are masked? idf so which type i.e. transistor or relay output IRRELEVANT it was YOU introduced the wrong info about selection
your not adverse to dragging me or others back to comments in past unrelated posts - actually its not something I do so i thought i'd just pay back the compliment to you, while we are at it and passing the time of day, so how will loopng out a zone at the panel with a link disable a zone on an en eol system? your at it again - what thread what comment ( be careful, with your failing memory you`ll probably have got this info wrong too)
that will be caught out then and just to embarrassed to answer properly? your talking to yourself again, arnt you?
regs
alan
As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
Guest anguscanplay
its a father and son thing again - there wrong and should have retired years ago, but wont admit either LOL
