Umster Posted February 22, 2008 Author Posted February 22, 2008 ring them. 01616555500......are you thinking about installing alarms.....? Yes, I can always add that to my trade!!! It's something that interests me alot. maybe I can give you a call and we can have a chat?
aptsys Posted February 22, 2008 Posted February 22, 2008 where can I purchase guardtec kit from? You can get Gardtec panels from securitywarehouse.co.uk
kka Posted February 22, 2008 Posted February 22, 2008 which area are you in, and did you contact Risco..... Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest anguscanplay Posted February 22, 2008 Posted February 22, 2008 The Infinite wireless alarm system is not bad.Ive fitted a few without any false alarms. False alarms are just the same as with a wired alarm, all depends on PIR location ect.. Control panel is mains powered, bell box is by 12v transformer in the loft. PIRs are battery operated so you will have to change batteries about every 18 - 36 months.
Umster Posted February 22, 2008 Author Posted February 22, 2008 which area are you in, and did you contact Risco..... kka, I will be contacting Risco on monday morning Thank you for guiding me in the right direction, much appreciated. Best Regards Umster
Umster Posted February 22, 2008 Author Posted February 22, 2008 oh dearoh dear, oh dear oh dear, oh dear, oh dear I need to go and lie down in a darkened room for a while well done!!!! you picked up my mistake!!! I new to all this alarm stuff...forgive me!! so what prima you got?
Guest anguscanplay Posted February 22, 2008 Posted February 22, 2008 well done!!!! you picked up my mistake!!!I new to all this alarm stuff...forgive me!! so what prima you got? its says suPRIMA 40 ? and the tank in the airing cupboard has a big metal ball on top
pontypirate Posted February 24, 2008 Posted February 24, 2008 oh dearoh dear, oh dear oh dear, oh dear, oh dear I need to go and lie down in a darkened room for a while Nothing wong with running a spur off a bedroom light as long as you protect it with a 3 amp fuse.
pontypirate Posted February 24, 2008 Posted February 24, 2008 Cool, thanks for that.if the bell box use a 12v transformer, I take it that you can take a power feed from the light circuit? correct? what are the wireless door contat like? how does it compare to the Response SA5 system The door contacts are great. I have only fitted 3/4 bed semis but have never seen the signal strengh dip much below maximum. And I've got a PIR in my own detached garage. the signal travels through 3 brick walls and is still almost on max. Never used the Response alarms. They operate on the 433 MHz frequency which is a bit like the M25. Anything can use that frequency Wireless doorbells ect.. Yale and Micromark also use 433Mhz and should be stayed clear of. Infinite use the 868Mhz frequency wich has been set aside in Europe for wireless burgular alarms and is very reliable.
Guest anguscanplay Posted February 24, 2008 Posted February 24, 2008 Nothing wong with running a spur off a bedroom light as long as you protect it with a 3 amp fuse. hmm - till the next owner plugs something else into the socket ?
