camerabloke Posted February 24, 2008 Posted February 24, 2008 what will you say when your house catches on fire and maybe kills someone because you cut a corner? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
mjw Posted February 24, 2008 Posted February 24, 2008 The bell box uses 25 m (Milli amps). I'm happy that my lighting circuit can cope with this. I'm not going to spur off a bedroom socket for this and have unsightly trunking just for that.If you dont like it. TUFF. to be honest i dont think anyone care what you do,but you may as the fire engines turn up i just hope they dont turn up too late
pontypirate Posted February 24, 2008 Posted February 24, 2008 what will you say when your house catches on fire and maybe kills someone because you cut a corner? And why would my house catch fire exactly? 3 amp fuses go on strike when they are on a lighting circuit do they? Up and down the country there are houses running low voltage TV signal boosters in the same way. Maybe next door to you!
mjw Posted February 24, 2008 Posted February 24, 2008 And why would my house catch fire exactly? 3 amp fuses go on strike when they are on a lighting circuit do they? Up and down the country there are houses running low voltage TV signal boosters in the same way. Maybe next door to you! may be .but then saying that the next door house is about a mile away so that wouldnt really bother me
pontypirate Posted February 24, 2008 Posted February 24, 2008 you do what you want, the problem is your now telling others to do it that way too Look kids, Dont try this at home!
barooga Posted February 24, 2008 Posted February 24, 2008 The bell box uses 25 m (Milli amps). I'm happy that my lighting circuit can cope with this. I'm not going to spur off a bedroom socket for this and have unsightly trunking just for that.If you dont like it. TUFF. Way to go. A man of principle and standards. Pretty damn low ones mind. Growing old is mandatory, growing up is optional
mjw Posted February 24, 2008 Posted February 24, 2008 Way to go.A man of principle and standards. Pretty damn low ones mind. standards...now that is questionable
Cubit Posted February 24, 2008 Posted February 24, 2008 The bell box uses 25 m (Milli amps). I'm happy that my lighting circuit can cope with this. I'm not going to spur off a bedroom socket for this and have unsightly trunking just for that.If you dont like it. TUFF. So, some wireless systems not so clever afterall eh.
Guest anguscanplay Posted February 24, 2008 Posted February 24, 2008 And why would my house catch fire exactly? dunno - maybe the transformer doesnt like it in the loft?
kka Posted February 24, 2008 Posted February 24, 2008 Unless the feed goes directly to the consumer unit then even better. it is my understanding, that even here (consumer unit) you must connect into a existing ring main circuit, as to put it on its own, is to create a new circuit, which is then covered by part P........ Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
