valks1 Posted February 20, 2008 Posted February 20, 2008 Hi I have a Eurosec CPX system. How do i program the LCD keypad to use the part set function. I have been through most of the settings but can not find it. I need to set which zones i want on during part set mode. Also can i set the chime function for front and back doors ?I have them both set as entry/exit but only the front door chimes. Advice would be greatful.
ViperMK2 Posted February 20, 2008 Posted February 20, 2008 They are both in the same section of Zone attributes: Enter the zones you want to be off in part set 1, 2 or3. next is chime: enter the zones you want to chime: zone 1 on by default. there are 2 chime options, Chime 1 and 2. chime 2 makes a different sound so you can tell which door has been opened. if there is a PIR at the bottom of the stairs make it 'E/E in part' otherwise it will activate when they go down. It may be better to make part set as silent, speaker will bleep after the exit time has elapsed. make sure the customer likes the volume of the chimes and sounders in general. If it's too loud it can be annoying. Sometimes the chime from the keypad is enough. As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
kka Posted February 20, 2008 Posted February 20, 2008 you have to tell this panel, which zones you want to turn off in the various part sets and its the same with the chime suites of which there are twoi.... tbh if i was standing next to the keypad i could show you no probs....but trying to visualise it and then explain it , this way is quite difficult....do you have a manual? Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
ViperMK2 Posted February 20, 2008 Posted February 20, 2008 tbh if i was standing next to the keypad i could show you no probs....but trying to visualise it and then explain it , this way is quite difficult....do you have a manual? They only come with a quick start manual, thank god he's not doing the Radio side of it As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
kka Posted February 20, 2008 Posted February 20, 2008 yes, had to go down to risco to get mine. a days training, met all the staff. met the tech guys. brilliant. it was well worth the effort. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
kka Posted February 20, 2008 Posted February 20, 2008 They are both in the same section of Zone attributes: Enter the zones you want to be off in part set 1, 2 or3. next is chime: enter the zones you want to chime: zone 1 on by default. there are 2 chime options, Chime 1 and 2. chime 2 makes a different sound so you can tell which door has been opened. if there is a PIR at the bottom of the stairs make it 'E/E in part' otherwise it will activate when they go down.It may be better to make part set as silent, speaker will bleep after the exit time has elapsed. make sure the customer likes the volume of the chimes and sounders in general. If it's too loud it can be annoying. Sometimes the chime from the keypad is enough. the volume can be adjusted in the menues on the cpx... he can fit the radio later if he so desires....nice little key phobe and all that Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest anguscanplay Posted February 20, 2008 Posted February 20, 2008 zone 1 on by default. but your still only learning LOL
arfur mo Posted February 20, 2008 Posted February 20, 2008 to clarify, when you get to part set 1 settings it shows no zones, so press 'NO' then 'zone number' and 'YES', that zone appears in the window, repeat as required. if you input a wrong zone, press 'NO' - 'zone number' and 'NO' to delete it regs alan If you think education is difficult, try being stupid!!!!
valks1 Posted February 21, 2008 Author Posted February 21, 2008 Thanks, i have set the part zones up now. But i cant find the chime zones again ? Any idea where they are ? under which menu ?
ViperMK2 Posted February 21, 2008 Posted February 21, 2008 in zone attributes. scroll through until you get to chime As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
