Maximum Cable Lengths
IA76
Hello
What are the maximum cable lengths for video & 12v power cable to a cctv camera with infrared?
TIA
Depends on the current draw and the thickness of cable.
12V IR's even if LED can pull some serious current so cable lengths should usually be as short as possible and in flex rather that alarm cable.
We usually get a mains cable dragged out to the camera to save the day...
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
The specs for the camera show:-
Operating Voltage: 12V DC 750mA
What about video cable? What is the max length for that?
750ma on alarm cable (single cores)= approx 16 metres
750ma on 1mm T&E= approx 70 metres
Basically the thicker the cable the less voltage drop.
IIRC RG59 video cable is good for approx 250/300 metres, if you use CAT5 and baluns you can go approx 500m with passive baluns and 1km with active baluns.
Whos BRETT???
LOL
