Concept 6 Alarm Bell Not Ringing
saz2008
Hi again,
This seems like a job that will be given to a professional, but just for my information, what would be the cause of a bell not ringing and a strobe not flashing in the SCB? That is both under test and under alarm conditions.
The panel etc are working fine, and the internal sounders are ok.
When the alarm was disconnected it followed a mouse attack on some cabling to the RKP and I was unable to turn it off, so disconnected power and let bell battery go flat. Battery in bell could well have been flat for 2 years or more now. Is the battery integral to the operation of the bell?
Is it a fair guess to assume the flat battery has leaked destroying everything up there, too high for me to get to, and a new bell box is in order?
Guest anguscanplay
fair guess the mouse has eaten the bell cable too :yes:
lol, the wires head off in different directions, and bell wire is definitely mouse-bite free.
Guest anguscanplay
we`ll see - let us know what the engineer finds
No, i have traced the bell wire from panel to inside the wall where the bell box is sited, and its integrity is intact, this was one of my early thoughts. So it just all goes wrong on the outside wall... wall itself is 3' thick stone, no cavity, ergo no mouse.
Guest anguscanplay
lost one myself to a squirrel inside a stone wall just last week (the only good squirrel is a dead squirrel as Custer would have said if he`d been me LOL)
has the system been down for over 2 years then ? if so it could be anything and everything
everything works except the outside bell and strobe, alarm is back in daily use with internal sounder at full volume..
All i want to understand is whether the bell needs a working battery in it to operate correctly?
were it not for my ladder phobia it would be sorted! :smash:
Why would it need a battery if it would operate without one?
can a bell box just die then? It's in a harsh environment where security lights only survive a couple of years before corrosion gets them... hmmm guess i've just answered my own question
Corrosion like that, you on the coast? If you are ........
When replacing at the very least make sure you get a sounder with sealed electronics
