valks1 Posted February 22, 2008 Posted February 22, 2008 Hi I have a Eurosec cpx system. Can someone tell me how to program new users in ? The only option i can find is to change the engineers code. Please help
camerabloke Posted February 22, 2008 Posted February 22, 2008 dont try changing the codes when you are in engineer mode Eucam Security Systems 0845 4630 746 www.eucam.co.uk
advancedprotection Posted February 22, 2008 Posted February 22, 2008 enter user code. press no till "do you want to program user codes" press yes enter user no press yes press no enter code press yes enter user text and press yes press 0 3 times Martin Trade Member It's nice to be important but it's more important to be nice!! Martin Hanfo CCTV - Intruder Alarms - Access Control - Security Lighting - Locks Covering South Wales 07903 967045
ViperMK2 Posted February 22, 2008 Posted February 22, 2008 you can only change user codes in user mode, eng mode does other things As the days go by, we face the increasing inevitability that we are alone in a godless, uninhabited, hostile and meaningless universe. Still, you've got to laugh, haven't you?
Guest anguscanplay Posted February 22, 2008 Posted February 22, 2008 enter user code. press no till "do you want to program user codes" press yes enter user no press yes press no enter code press yes enter user text and press yes press 0 3 times Martin you sure about the step in red ? - its a CPX not a CP8L
valks1 Posted February 23, 2008 Author Posted February 23, 2008 Theses the problem when i powered up the system i only program the engineers code, as i was setting it up. How do i add new users now .? As the above option does not appear.
magpye Posted February 23, 2008 Posted February 23, 2008 Theses the problem when i powered up the system i only program the engineers code, as i was setting it up. How do i add new users now .? As the above option does not appear. Exit engineering, change the code using the default user code Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
camerabloke Posted February 23, 2008 Posted February 23, 2008 Deja Vu Eucam Security Systems 0845 4630 746 www.eucam.co.uk
arfur mo Posted February 23, 2008 Posted February 23, 2008 Theses the problem when i powered up the system i only program the engineers code, as i was setting it up. How do i add new users now .? As the above option does not appear. you have to be in User Mode not Engineer Mode, then you have to use a MASTER USER code (User 1 by default) to access the 'change user code' menu's. the panel works on a simple yes or no, i.e. do you want to Set? (note the question mark) so in put Yes to access that option or No to move on to the next option. regs alan If you think education is difficult, try being stupid!!!!
