Gardtec 800 - Service Required Call Engineer
alarmed17
HI everyone, we have just bought a house and it has a gartech 800 alarm
it was all working fine then it came up with service due in 2 weeks, please call engineer, the problem is we cant get hold of the contact the old owner of the house used.
is there a way to disable the warning/time out.
as far as i am aware its not a monitored system, we have the user and master code but thats about it.
cheers
cheers
hi,
this is a 'service due' reminder, unfortunately after 14 days it might 'lockout' the panel from further use. you need a decent gardtec aware engineer to remove the setting, as it's done from engineer mode.
you need a 'gardtec' engineer as also quite likely the installing engineer/company have 'locked' the engineer code which will prevent access and removal of this setting without the know how.
i don't personally set this timer up unless asked to by the client, and alarms should be service preferanly every 12 months so this may well have happened with the previous owners, and may not just be a ruse to make more money for the installer.
either call a few local companies or i'm sure some on here local to you will make contact shortly.
regs
alan
If you can't get the engineer code and it is burnt in to the panel you will have to change the pcb for an 816 as the 800 is no longer avalable (good news if any is the 816 pcb will fit as a direct replacment in the existing housing ) good luck with the code hunt.
www.AllanMoncrieffAlarms.com
there are ways to recover if it is 'burnt in' but you need acess toa 'pic blower',
if changing the panel i'd recommend to go for a G490 and new keypad, far better software and a built in VoCom voice dailer. being an 800 likely a far better looking keypad than the ugly old square LED monstrosity :P
regs
alan
regs
alan
never heard of a pic blower could be a usefull tool as we have had to change a few panels with burnt in codes ( mind you puts up the profit margin on the job ) so may be not so handy a tool
I have two gardtec 800 panels with locked codes just sat doing nowt.
I must arrange to meet Arfur and pass him some drinking vouchers in exchange for "releasing" the locked codes!
tbh, i don't know if it's really worth while unless on an existing bells only'. the software has changed so much with the newer models and the older ones don't comply with En or PD, and really early panels don't do UDL.
so i tend recommend swapping out to a G490 or G595 for the VoCom and G-Tag options.
regs
alan
there is another way of removing the locked out code it only works on the older type panels and doesnt require software wish i could say but its not allowed . is there anywhere where engineers can share this type of information.
Guest anguscanplay
yep - maveric was the last one who posted it, in the trade side of the forum
theres a form somwhere you can fill in to get trade accredited
